Arctic Cat adjusters for IceAge rails
mutley531
New member
Can someone give me a list of the Arctic Cat parts required to use with IceAge rails built for the Timbersled skid? I have ordered the skid and I have already got the rails and the 2 wheel kit from IceAge. Also, any pictures of the setup would be greatly appreciated.
Here's a pic from the arctic cat parts website. I did the three wheel parts from an 05-06 M series and bought 8" composite wheels from WPS. However, the WPS wheels use 15mm wide bearings whereas AC uses 12mm. So now the spacers between the wheels need to be shortened to make up for the wider bearings.
Yamaha bump stops and caps, polaris hifax, arctic cat axle assembly. I'm not sure why Ski doo parts got left out of the recipe, but I guess that's just one less headache.
Here's a link to the AC parts website too. Have Fun
http://arcticcat.arinet.com/Empartweb52/scripts/EmpartISAPI52.dll?MF&app=ARC52&lang=EN&TF=Empartweb&LoginID=cotest&loginpwd=cotest&partner=ARCC
Thanks for the replies. Looking at the Arctic Cat microfiche, attached, it looks like I need #s 26, 27, 28, and 29 along with the adjuster bracket that bolts to the rail. I think with the 2-wheel kit the adjuster bracket gets moved to the inside of the rails, but it looks like the sleeve wouldn't do anything on the axle side of the the adjuster bracket (as shown in the picture). Do I need this sleeve, or do I put it on the forward side of the bracket? Sorry if these are simple questions. Maybe once I get the parts it will make more sense to me. Is there something I need that goes on the end of the bolt which pushes on the axle or is it just the end of the bolt against the axle?
