Arctic Cat 975 ported CPC carbs
Meatman
694
Motor is back on the market. Here is a good collection of pics http://s20.photobucket.com/albums/b2...7/975%20motor/ can take more if needed.
I am asking $3000 for this motor and everything with it
RKT monohead with high compression domes
Cylinders - Bored to accept M1000 pistons w/pretty radical port work.
2 Brand new factory m1000 pistons (I always send new pistons with my motors)
Bottom end - Crank trued and welded, oil delete kit. All bottom end work done by speedwerx
M1000 recoil adapter and recoil
Shims to raise the cylinders for the m1000 pistons.
Magneto w/housing (carb)
STM mechanical power valves
Boysen Rad Valves
CPC 54mm race carbs (will include jets and set ups for both high and low altitude)
-Also has TPS bracket and TPS on the carbs
-Will include throttle cable and throttle block for carbs
MSD ignition wires for a little extra spark
SLP twins w/front dump jaws stingers
CDI box for high altitude, also have low altitude box available
Will throw in UNI filterpods
Also have an avenger 3 EGT with probes and power wire if interested.
This is a complete, very reliable motor. It is the product of 4 solid years of testing different combinations of parts and brands. Easy to set up, and tune. With the carbs having 3 powerjets with external adjustments on them, you dont have to spend all day with the hood up if the weather gets warmer or colder.
