Arctic Cat® Model Year 2023 Full-Size [IMG alt="A picture containing object
Description automatically generated"]https://lh3.googleusercontent.com/I...BoTHPcMuR_C2lAmWsmJyMlyaj8WyC8dRO8_EZoi[/IMG]
Sport Utility Offering
For Model Year 2023, the Norseman X 8000 returns with all-new colors and graphics.
The Norseman X 8000 is powered by the C-TEC2 794cc, 2-stroke 8000 Series with 165-class horsepower. The engine is paired with the Arctic Drive System™ that includes the Arctic Cat ADAPT CVT System for improved performance and serviceability. The lighter-weight ADAPT CVT system features a narrower design and an advanced idler system that maintains constant belt tension throughout the ride—resulting in minimized wear, longer belt life and smoother power delivery at slow speeds. The system also provides a smooth, consistent drive-away in all snow conditions and a low starting ratio to optimize deep snow use and towing of cargo.
Up front, the Norseman sleds feature the Arctic Race Suspension™ (ARS™) with 9 inches of bump-eating travel. The front suspension is coupled with 10-inch Pro-Ute skis that taper to 8 inches wide at the center and an adjustable 35.5- to 41.5-inch ski stance. In the back, the model offers 13.5 inches of travel from the XTRA-ACTION Rear Suspension with adjustable torsion springs and Torque-Sensing Link rear arm. The XTRA-ACTION Rear Suspension works to keep the rear of the frame articulating or “tipping up,” which keeps the sleds climbing and staying on top of the snow when in reverse, rather than sinking. The rear suspension can be unlocked for more maneuverability or locked for increased traction, depending on the needs of the rider. The Norseman X 8000 is offered with a 153-inch Power Claw™ track with 2.25-inch lug. The unit also features Arctic Cat IFP 1.5 shocks all around for superior ride control and comfort along with excellent fade resistance, even in the harshest conditions.
The Norseman X units have Arctic Cat’s next-gen bodywork and 14-inch mid-height windshield. Other features include a deluxe digital gauge, electric push-button start, sport bumper, 6.5-inch handlebar riser, tow hitch, rear rack, tunnel bag and dual halogen headlights. The models are available in Black/Fire Red with new graphics. An accessory kit is available that includes front bumper, rear storage and an 18-inch windshield.
All 2023 Arctic Cat snowmobiles will be available for pre-order during April 19 – May 3. For more information once the program launches on April 19, visit a local Arctic Cat dealer, or go to ArcticCat.com and use the new buyer’s guide to find the perfect sled for you, and check out the updated sled builder to visualize different track lengths, colors and accessory choices. Join the conversation on Arctic Cat Snowmobiles’ Facebook, Twitter, YouTube and Instagram accounts.
Norseman Technology
8000-Series C-TEC2™ Engine
The next-generation 8000-SeriesC-TEC2 engine delivers a new level of clean Arctic Cat 2-stroke engine performance and technology. This 794cc C-TEC2 twin features:
This advanced new technology designed by Arctic Cat delivers:
ADAPT CVT System
Arctic Cat-designed drive and driven clutches for increased performance and better serviceability. With a lighter-weight, narrower design, and an advanced idler system, ADAPT maintains constant belt tension throughout the ride—resulting in minimized wear, longer belt life and smoother power delivery at slow speeds. The system also provides a smooth, consistent drive-away in all snow conditions and a low starting ratio to optimize deep snow use and towing of cargo.
Pro-Ute 10/8 Skis
10-inch Pro-Ute skis that taper to 8 inches wide at the center.
Arctic Cat IFP 1.5 gas shocks
Ensure ample shock absorption.
Power Claw™ Track (Norseman X 8000)
153-inch with 2.25-inch lug.
Norseman Technology
- Cylinders, pistons, combustion chamber, flywheel, and fuel rail, all updated in 2020
- Fuel calibration strategy and Arctic Power Valve system with 3-stage control of the auxiliary exhaust ports via side valves, new in 2020
- ECM-controlled electronic oil pump
- Batteryless EFI
- Engine Pipe Temperature Sensor (EPTS)
- Knock sensor
- Engine reverse technology
- Ultra-clean, more responsive performance
- Enhanced power in the 165-hp class of engines
- Precision oil injection
- Exceedingly robust and lightweight design
ADAPT CVT System
35.5-41.5-inch Adjustable Ski Stance
Easily adjust the ski stance for maximum adaptability.Pro-Ute 10/8 Skis
XTRA-ACTION Adjustable Rear Suspension
The XTRA-ACTION Adjustable Rear Suspension delivers the best maneuverability on the trails and ultimate traction for towing and hauling.Power Claw™ Track (Norseman X 8000)
