Listen for 3-5 second cycle of fuel pump when you turn key on, if you dont hear this check fuel pump relay, when key is turned on this relay should click once then should click again after 5 seconds,if it does click on & off you need to check for power at fuel pump connection, if you have power at conn. & pump doesn't run you need pump. if you don't have power at conn. replace relay. If the relay doesn't click w/cycle of key you need to check powers & grounds at relay, this gets a little more tech. & you will need wiring diagram, I used to have diagram, let me know if you need diag., I will see if I can find it. I could be wrong but I'm pretty sure injectors don't cycle w/key on. Good luck!
