Apex turbo secondary tension help!
MR MOOSE
I've been reading all the clutching threads trying to get an answer to this without bothering everyone with more clutching questions but no luck so here goes;
I've got a MCX 310 kit that I'm running 15-17lbs from. A 163" flex edge track and EZ RYDE skid. The primary clutch is BWB with 85g weights and 14.5 rollers. The secondary is purple spring with a shockwave helix.
I went for my first ride yesterday and on a good pull I felt the secondary slip, got home and went to tighten the spring up but too little too late! Secondary is toast, big groove in it and a nasty crack. I got another secondary and put it on but want to make sure I got it right this time. It was set at 3 turns out on the shockwave and 3-3 on the spring. I put it back together at 2 turns out on shockwave and 2-9 on the spring. Am I close or out to lunch? 2-9 was one hell of a twist! Heading to Revy on Friday and want to have a good time and not saw another secondary in half!
Sorry for the long post, thanks in advance for any help!!:sorry:
are there any grooves on the shockwave arms that would be causing it to bind and not open properly? the settings that you changed to is where i run mine. the secondary spring, i find, loses its strength quickly. i change it out almost every year.
Boost mod, first thing is sorry! I was trying to hit the quick reply button using my I phone and ranked your post as not helpfull. That's not what I meant to do, anyone know how to fix that? Thanks for the help, I checked the ramps and they seam good? Also I had just put new buttons in too. If your running my current setup without issue hopefully I will have the same luck.
I run 47 degrees on my shockwave, which is only 1 1/4 turns out. Any more than that and I had belt heat. Yours is 3 turns out which is 54 degrees, that is too much helix IMO and probably your problem. 3-3 is plenty tight on your spring. I run 2-3. make sure that no snow is getting into the clutches. I fought that too. Just my 2 cents.
I am agreeing,
...beyond the limits on the "shockwave" will kill your belt in the secondary, ..or vice versa. I would take it one step further and say ,...just buy a straight 47 helix, cant go wrong with that. 2-3, or 3-0 on secondary with a purple spring should do it. As stated above, be sure you don't get any snow drifting in....
I am agreeing,
I actually ditched my shockwave last year for a yammi 47. 8bv71 is the yammi part number, if I remember right. Shockwave is hard on buttons too.
What did you end up doing with the gearing after that last thread. The purple EPI spring, the black Alpine and the Cat green are all the same spring. Put a Yamaha straight 47 in there and sell the Shockwave.
M5
I ended up going with 19/40 gearing. I do have a 47 helix outa my old viper, maybe I will throw it in. What tension u figure?
