Apex Rear Suspension - removal
Headrush
I am going to run a 2 wheel kit in my Apex and was wondering how hard it's going to be to pull the rear skid? Any tips, ideas to make the job easier?
I tired doing a search on the forum, but couldn't finad anything....
Thanks!
Loosen the track elevate it and pull the four bolts when you go to put it back in front first and then use a ratchet strap compress the rear shock a little and line it up to the bolt holes its easy one guy can do it in about 10 minutes at most
hope this helps!! Did you buy your axle kit yet i have on for sale it is a mmp for $75.00
thanks
even easier yet... no straps.
unhook the torsion springs from the front mounts. take off the rear mount bolts, front mount bolts, pull skid. takes about 10 minutes. 15 if you drink a beer between the two bolt sets. reinstall same way, front bolts, rear bolts then the torsion springs. ski
