Apex/Nytro motor mounts
The mounts are different angle, apex motor sits more upright compared to nytro mounts more laid back, they are pretty close apex motor bolts up in a nytro, motor mount wise.
The motor mount center to center distances on all the motors is the same, so thats Apex, Nytro, Vector and Rx1. If you are wanting to put a Nytro motor in a Deltabox chassis it'll bolt right in, it will sit differently than the Apex/Rx1 block but it'd basically be a fuel injected Vector. The center to center distance for the clutch will be the same at 262.5 mm but the primary clutch will sit lower and a bit back in the chassis comared to the Apex engine.
M5
It's a alot of work, no major welding or fabbing, but very time consuming fiddling with all the small things fit properly.
