C
cadmo
Ok so my new to me 06 Apex mcx 310 with snow performance water/meth injection variable rate from start around 10 psi boost to full flow by 18 psi, ran amazing last ride at Golden,
Runs 18psi
With 94 octane and the water/ meth injection, knock box didn’t go off once
But this ride out at Revy it had a horrible mid-range mis/backfire, and kind of drown out, when out from full throttle. Once and a while it would do it top end as well.
During the last day i dumped out the 50/50 water methanol to windshield washer fluid (about 35% meth), then to strait water. Symptoms didn’t change all three times.
Does anyone have ideas?
Also what is the max boost psi I can run on strait 100LL stock engine with head shim, as the previous owner neglected to mention that it uses a TON of water meth during the day.
Runs 18psi
