I see your new to sw so for the record this is the swapmeet where people sell/buy turbo/supercharger/nitrous stuff. No worries, you might want to post in the "yamaha" section of the forums with questions about your 4 stroke questions. That being said...
The bd numbers will be fairly close. You certainly don't need a dyno to dial it in. To tune you need a wideband which bd sells. All you need to do is add or pull fuel to get around 12.5 a/f ratio on race fuel. If your running pump gas tune for low 11's. Clutching I would run primary:blue/white/blue with supertip weights 2 tungsens in heel, 3 grams in middle tips empty. Secondary shockwave adjustable helix set around 51 deg and a yamaha white spring. This clutching will work at 14-15 psi or so. Just a good place to start anyway, you can tweek it to your likings. If you need any other help send me a pm if you want.
