Apex and fuel Pressure guage
philsummers21
Im in the process of getting my apex back together with a new engine and boost-it kit. Im going to mount a fuel pressure guage in somewhere. Just wondering where everyone else has tapped into to get there readings and if by chance they know what fitting. I dont have it together far enough yet to figure out where to tap into. Could i tap into it right off of the boost-it fuel rail?
you have to tee it in- between the fuel regulator & the fuel rail i have mine in the nose of the sled but you can put it wherever you like.you only really need it for setting your idle fuel pressure then if you have issues it can help out allot,but dont need it all the time.
Ah yeah it does need to be after the fuel regulator. Yeah id just rather mount it up under the hood somewhere and be done with it instead of having to find one and mount it all up if i ever needed it.
Fuel pressure tend to change a bit with altitude... so have it where you can see it for reference if you have troubles.
