Yes.
I have changed out my $40+ dollar stock cap and replaced it with an $8-$9 cap that does not leak. It is just a cap, and it does not tell me how much fuel is in there.
http://www.skessnowmobileparts.com/
Mine leaked from the dome too and it just got worse over time. The glue had deteriorated enough to start causing the leaks. I used a screwdriver to carefully pry the clear dome loose. Then cleaned up the old adhesive and re glued it with epoxy, making sure to create a good seal at the same time. Good to go
Sorry no part #. I believe it is a non vented oil/gas cap. The last two I bought were $8. Maybe call these guys.Do you have any pics are a part number? I'm tired of mine leaking and would like to find a new one.
Think super glue will work or what kind of epoxy.
