Anyone try the new hard motor mounts
Has anyone tried or heard of anyone using the new hard motor mounts? I am looking to get a set am try them on my m1000 to help the belt blowing problem!!!
Here is a link to themhttp://www.theoutdoorshopinc.com/performance/product_info.php?products_id=225&osCsid=5441769a157931efeef23fd6a30e38e9
Those are made by Supreme Tool Inc. and were just released. Doubt many have them on yet.
Aaron
Just buy the solid mounts from Cat.
They use them on the front PTO side engine mount bracket.
Have someone press them in, replace all three.
I had it done, definitely better but after a 1000 miles I am still seeing some wear and cracking on the solid rubber. I think it would be better with the bottom engine mounts kits made by Twisted Turbo or Arctic Edge Motorsports along with the solid rubber side plate mounts.
http://www.snowestonline.com/forum/showthread.php?t=163693
What are the differences between the '08, '09, and '10 engine mounts? I know the changed the '09s and put a solid mount in the front of the PTO side plate, but what did they change on the '10s? All three have different part numbers. Be careful putting solid mounts at all three mounting points. I have heard that can lead to the bulk head cracking. I was told to just replace the front one with a solid mount.
I put three solid mounts in on the plate and one in the back corner last year, EXTREMELY BAD IDEA! Not only did it vibrate like a mofo, but it broke the rear corner mount on the bulkhead and cracked the bulkhead behind the secondary clutch, The bulkhead mount was not easy to fix and I'm always waiting for it to crack again. So I went back with all stock ones except a solid in the front corner like the 09, all has been good since.
