Anyone tried running the 3" track with a chaincase?
Somescreenname
I was told if you are going to run a 3" track on an Assault/chaincase, that the front and bottom edge of the chaincase need to be modified in order to create enough clearance to compensate for the smaller 7 tooth drivers. Has anyone out there run a 3" track without modifying the chaincase? I am hoping what I heard is wrong because not really wanting to pull and modify the chaincase.
Thanks!
You have to modify the case. Just as told,
Sorry I feel like its one of those post
("So I hear they make a drop in piston for the pro? Which is best?")
That billet drop & roll from iceage looks killer! Plus then you should be able to stick to 8 tooth drivers.
