I have one, not real impressed with it. My cooler on the bottom of the sled leaks. Seems like casting flaws. I've welded it twice now. Also seems like the pump is always churning air bubbles. I'm either going to revamp the whole thing or take it off. Another thing is the intake temp sensor is ahead of the intercooler. So when the air is hot on the sensor then cooled going into the motor, is the fueling map going to be off? Just wondering. It looked like the boondocker has the intercooler right off the turbo, then the sensor down stream to read the actual temp of air going into the motor. Does any of this make sense?
Sent from my SM-G900V using Tapatalk
The sensor on the intake tube is a MAF sensor and does not measure air temp. There is not an Intake temp sensor on the sled. The only temp sensor is the one the top of the head cover which is for fluid temp.
No worries about the map changing. The cooler air rushing into the engine will only help things.
I believe these sleds run a T-map and a combination of speed density and alpha-n, they definitely aren't MAF though. The T-map measures IAT as well, and IAT is necessary for any properly running EFI system.
Oh, I was under the impression it was a pressure and temp sensor.The sensor on the intake tube is a MAF sensor and does not measure air temp. There is not an Intake temp sensor on the sled. The only temp sensor is the one the top of the head cover which is for fluid temp.
Anyway I still don't know what to think of the whole thing.
