Anyone remember the headlight mod?
Like 6 years ago I used to know how to wire the headlights on a gen2 so that all the lamps burned at once when the brights were on. Anyone remember what I did?
Just take the lead from the high beam and run it to the two side lights,I think its the org wire on mine,but I got rid of the two side lights.
Does anybody else have anymore information on this, I would like to do this to my Gen2, the headlights arent near bright enough on high beam? Thanks in advance.
Y/R wire is the hot side for the high beam with brown as the return side. GRN is the hot side for the low beam with brown as the return side. I would think you just jumper the Y/R to GRN to turn all on at the same time.
i just got done doing this to my 00 RMK you take and run a jumper wire from one of the hot wires on the high beam and run it to the middle spade connector on the low beam bulb. just go to a parts store and get the three wire pig tail for that style headlight and wire it in works great.
It doesn't overload the stator at all running all the lights at the same time?
