Anyone received their 2018 MC ?
Goin For Snow
1,110
230
South Haven MN
dont know if this answers your question but on the demos i seen on the lockout, i couldn't get the bumper to move at all. Its a very stiff valve setting.
Chewy22
1,999
1,382
Montana
Have not seen one in person yet but heard the tunnel green is not the same as the 16le and 17MC. Sounds like it's closer to the same color of green on the 17MC spindles, yuck! For $13/14k there should be more then one color option, in the model you want.
  • Like
Reactions: d1100t and cpa
CO 2.0
2,994
Fort Collins, CO
They just need to keep it simple, as in BLACK! But seriously, Polaris has like 19 plastics/tunnel color combos. Not like I care about what color my sled is, but people who are talking crap about us complaining about lack of color options... how does a pink and brown sled sound to ya? :face-icon-small-ton
  • Like
Reactions: d1100t
DDECKER
4,770
1,780
CRAIG COLORADO
I didn't like the pictures but I do like it in person, and to be honest id ride a hot pink sled too I don't care as long as the sled runs :)
d1100t
1,814
400
83
Saskatchewan Canada
Sled color
I'm also one that wishes there was a couple more color choices!
I'd love to order a 2018 mountain cat but I can't make myself order it with that green tunnel.
If the tunnel was black I'd order it tomorrow.
Doesn't sound like there's any chance of that happening so I guess I'll have to order a snopro and make it as close to a Mountian cat as I can.
Vertical-Extreme
1,555
500
Airdrie, Alberta
www.airdriejudo.ca
Or you could buy a black tunnel wrap.... way cheaper than upgrading the parts to change a snopro to a MC
  • Like
Reactions: d1100t
summ8rmk
Most handsome
12,369
6,043
yakima, wa.
Buy the MC and spend less than $200 for a wrap on the tunnel, make it what ever color or design u want
last
  • Like
Reactions: j&j cat and d1100t
d1100t
1,814
400
83
Saskatchewan Canada
Your right.
I know I could put a black wrap on it. It's just How would you get it completely blacked out inside and outside including the rear drop bracket and front frame. There a lot of green to cover in spots that isn't easy to get at???
How durable would the wrap be inside the tunnel and on the rear drop bracket?
If the tunnel was black I'd have no trouble ordering MC.
I haven't had a green cat since 2004 900 1M.
summ8rmk
Most handsome
12,369
6,043
yakima, wa.
Let just a little green show, it may look better than u think.
My tunnel is all green, my blue wrap has the green showing and i like how it turned out.
last
M
Mar 1, 2008
254
67
Canada
I received mine 18' MC 153 yesterday and I tried it on evening. I has a 16' M8000 LTD before.
Engine break-in are totally idiotproof, 0.3h with a shutoff at 6500rpm, the engine are very lazy until 0.7h. After it, the engine take somes performance and power. I'm right now at 1.7h, I will see after the 5.7h break-in.
When the engine pass 0.7H, i noticed that the engine has SOME bottom and mid end. When you pin in at this range, it's a BOOM. Pushing hard. Throttle response is insane.
DEL headlight are amazing. Look so good and powerful light.
New Ascender chassis look like the Proclimb chassis, but it's get on top of snow and the sled are very predicable versus my 16' LTD and buddy 17' MC
Lower exhaust side panel melt on exhaust, i will put a heat tape.
QS3 shock are the best shock i never try. I ride 3-5 psi more that my 16' LTD with Fox Float Evol. At softer setting, it's like a LXR. Middle setting it's like a ZR, and stiffer setting is like a ZR SnoPro maybe a RR. Very good feature, i will like it when i get in and out of mountain.
I dont try the lockout because i'm alone in the dark so i don't take risks
RACINSTATION
7,503
3,459
Idaho
The lockout works awesome and it has a safety blow-by valves so if you hit it with massive pressure (big jump) it will release so it does not damage the shock. Very nice feature to step off, set it, and go.
We will have an update kit for the 2016-2017 and non MC 2018 sleds available Tuesday, and then a 2014-2015 kit a few days after that. Ill make a separate post for that.
