Anyone longtrack a RTX Nytro?
Nothing over a 2" from what I've read and that is tight. The MTX will allow a 2.5" stock.
i have a RTX as well i fit a 2" track with the cooler cut down by the windows and i fit it without changing my drivers, i do have 8 tooth extro intros and she would more then with a 2.5 is you cut all the stud protecters out, its the two long bars that run the lenght of the trunnel, but you can also go to 7 tooth drivers and not have to do anything but drop your track in and go, MTX have a 7tooth other then the drivers they shear everything else, ohh and the rtx dont have the cooler that runs under the seat so you might have some heating issues.
Thanks F-cat99
I will be using a 2.52 with 8 tooth extros, 9 tooth if they fit. I will be trying to use oem takeoff parts for the most part if I can get them shipped to Alaska for a fair price. We'll see what will fit. What lenght did you put under yours? Thanks
i keep mine a 121" 2", because i got a good deal on the track, but you will have to get rid of the stud protecters if you go to a straight lug, were mine is notched over all the windows so just keep that in mine, or by the one that they make for arctic cat moutain cats.
Im running a 162X16 In my Nytro . 10 hrs later it is in!!!! Now another 10 hrs to replace the tunnel with a cr162 tunnel and replace the track??? Opps not enough room with the Boost!!!! If my wife new???LOL
