looking for compression test info on 04 trx with je pistons 10;1 and 9;1, anyone know what readings should be for either ratio, thanks
That seems real low for 10-1. These sleds are stock at 12-1 and compression readings are around 206 # at sea level, but depending on the elevation that the compression is checked at the numbers will drop 3% per thousand feet due to the density of the air.i think je 10;1 should be around 130-135 for compression
dcturbo is that with je's?. i called dan at extreme machines and he told me the highest he has seen on his builds is for 10;1 is 135 ?
