Sometimes pistons may looks good but what you really need to check is piston to cylinder clearance. Also metal fatigue of the piston is invisible. And that can cause major damage to your sled. If your engine is apart I would strongly recommend changing the pistons with the rings. Will only cost you a fraction of the damage a broken piston can cause you.
