Anyone have a good way of storing tie down straps.
ndmtnsledder
I'm getting back to working on my trailer and looking for some good ideas on storing tie down straps. I have probably 2 dozen 6ft tie down straps I use in my trailer. I need a good way to store them that keeps them untangled and not rubbing on everything when not in use.
Me too I just throw mine into a big pile. Then when I need to tie down for trip home we say screw it and they sit in a pile til I get home
Sent from my E6782 using Tapatalk
Build wheel well cabinets up to the bottom of the window's. They'll be deep enough to store straps in but yet able to set a beer can on top.
In the trailer we use the owner put down those tracks you use clip in rings on to tie down sleds so he added 2 pieces on the front v nose horizontal 3 ft apart to clip the Un used rings on each side and tie downs tightened between them... If you need tie down rings and tie down straps just loosen the tie down strap and grab the rings... Clean storage of straps and tie down rings
Two pieces of E- track mounted on the wall. One just above the kick plate and one up by the ceiling. Pull them just tight enough to stay hooked. Works well don't get all knotted up either.
I'm selling these storage systems. Let me know if you're interested. $45. I can probably setup a group buy
Lol I already have a similar system to this excepts it's black yellow and says Macs Hardware and it was free. Maybe the orange one works better though it should for the price.
I just use my coat / gear rack hooks to hang them on when we unstrap them. That has worked for me for almost 20 years now.
When I can, I hook them on the wall of the trailer.
Otherwise, I "roll them" (wind like a roll of tape), then use a hair-band (rubber band), store them in the box.
I cut up bike inner tubes that have holes in them to make my own "rubber bands". Cut them to different souths to make them stronger if you want. Roll them up and put a band on and toss them in one off those soft tool bags. The bag is nice because it can confirm to the shape if the space you're putting it in.
Sent from my PC36100 using Tapatalk 2
I just use a cheap plastic clamp to hold the straps when they are wound and throw them under the back seat of my pickup.
I took some of the ideas from above and kinda combined them. I put a piece of 1" aluminum pipe through the support brackets for my cabinets. Then I can loop the straps over it and hook them to the etrack below.
