Anyone have a factory Nytro front half they can weigh?
SNWMBL
I should have weighed mine before starting my project but i didnt and its too late now.
I know it's a long shot, by I'm looking for a weight for pretty much a complete front half of a Nytro. This would ideally include the die cast sides, front cooler, steering hoop, subframe, clutch side steel motor mount, and subframe bolts.
I would also settle for the weights of the die cast sides if anyone has them lying around.
Thanks
I have all that stuff but I can't get you numbers till the weekend. If you don't have an answer by then I'll weigh it for you.
M5
I just bought the front cooler, steering hoop and on Monday i get the die cast sides. will see if i can get you some numbers.
I have a hoop as well. The subframe I did weigh by itself and I got 18.54 lbs without the sway bar. It would be nice to verify against someone else's numbers though. I really need the die cast sides & front cooler, and it needs to be noted if the weight includes any of the bearings.
Right side chassi plate : With both bearings, lower bearing retainer with the three bolts, 2 threaded engine mounts = 3,6 kilo or 7,92 lbs
Left side chassi plate : with steel bracket for engine mount and 3 bolts that holds it. = 3 kilo or 6,6 Lbs
Thank you! I got 2.1 lbs for the steering hoop w/o bolts. Just need the front cooler weight, and the weight of the 12 bolts that hold the subframe. I have a front cooler but its been cut up so the weight won't be accurate.
Engine, side plates, jackshaft, subframe, steering hoop assembled is 158 lbs
I,m guesstimating the engine is 110? Done on a bathroom scale
Subframe w/o swaybar brackets 18.54 lbs
Steering hoop w/o bolts 2.1 lbs
Right die cast side with both bearings and retainer 7.92 lbs
Left die cast side with steel engine mount & 3 nuts 6.6 lbs
Front cooler w/o protectors 2.95 lbs
12 subframe bolts guessing .5 lbs
38.61 lbs total
If anyone else could weigh the same parts so we verify these numbers that'd be great. It would be even nicer to get an assembled weight of the above parts if anyone can do that.
