Yes, when i bought my 11 pro, it had been turboed for a good bit of its life and had 900 miles on it. The pistons on top looked perfect I. E. no heat in ring lands, no det signs etc.. However, pistons and rings were sacked. Compression with a stock 12 head was 105 pounds and idle was rough. Rings were extraordinarily worn and misshapen. I replaced pistons and rings and compression immediately was back to a reasonable 123 pounds. Idles perfectly even when cold.
I still theorize that stock cooling on the Pro may have contributed to wear. Stock cooling without the front heat exchanger found on the rmk is lacking in poor cooling conditions even when scratchers are down. I added 100 square inches in the rear and it now works really well.
Sorry for long post. Hope it helped
Doesn't elevation have an effect on this as well?
Turbos are hard on rings.![]()
