Anybody build their own sled deck?
L
luv2sledmt
I am going to start building a sled deck for my F-250. Im wondering if anyone who has done this will share some tips and maybe a couple pics? Im tired of dragging around a trailer.:beer;
Had a friend who did one, had the skinny atv or dirt bike ramps and just ran 6 of the across his truck bed and bolted them on, then he got a fold up ramp and set it up aginst the side of the truck and ran em up there, he could fit 2 on a long bed
Here is a pic of what he ran across his bed
Frame, Bolts to frame using front and back box bolt holes.. Just use longer bolts..
Deck
Frame in truck
Single sled
Two sled
aluminum works great but steel is fine. either way for sure build the ramp out of aluminum (makes life much easier verses a heavy steel ramp).
Been planning on building a flatbed on my truck that operates about like that, but a but more heavy-duty since it`ll be the bed too, will also have pull out ramp.
I built one 2 weeks ago out of steel. I have the plans and can email them to you if your interested.
Only thing I would change next time is a shorter platform, and a shallower beavertail.
$400 in steel, 3 spools of wire, plywood and paint. Your probably not going to build it for under $700 in material, and it took me and my father 2 days.
sled deck
A couple buddies and I built one two winters ago. It works great, the only thing I would change is build it out of aluminum next time because its not light. We figured about 8 hundred bucks into it by they time everything was on there like tie downs and lights and things. Here are some pictures of ours, maybe that will get some ideas flowing for ya. You can see in the first picture where we made the ramp slide in just below the platform, and then the door we made in the beavertail in the second pic to get the ramp in and out. It works pretty well.
Got some ideas! Keep em coming!!! The aluminum rout might be a little spendy for me and i dont have an aluminum welding set up for my welder. So far like i said i got some good ideas!
I dont mind having a trailer and it fits my needs...............
I did see one that had telescoping sides so it could all slide back to regular width. Seemed to work pretty slick ?
I built mine last fall. Its steel because I don't have anything to weld aluminium.
I staggered the uprights midway up to allow for a wider ramp. I also built the beavertail and ramp hooks so that the ramp can no slide sideways when the ramp is positioned to either side or centered.
PS: an old plastic bedliner makes affordable ski slides!
n741660577_4991478_8166.jpg n741660577_4991479_8420.jpg n741660577_4991482_9193.jpg
hinge
what kind of hinge did you use so the sides can fold up...or am i just seeing things
ps. will get pictures of mine for you....
Those are weld on bullet hinges from the local industrial shop. The ones I used have grease nipples, but they are available without them.
I have drawn plans. If anyone is interested, just pm me with your email adress.
