I have a 07 m8 and put a wideband on it to check it before I started modding. Well the sled is bone stock except a RKT secondary, fuel regulator set to 44psi and the 08 updated ecu reflash. My sled may be a isolated case but you guys leaning out these sleds might want to rethink things I found on mine under almost all throttle conditions especialy wot it was around 13.9-14-8
When you move the throttle in fast the factory ecu appears to have a accelerator pump feature it's way rich like 10 and below for a second. Either my o2 sensor is in a bad spot or this thing is damn lean, I put the sensor on the inside radius in front of the temp sensor. I ordered a dynojet box but have not recieved it yet but when it shows up I will see if it will run better with tuning just for the hell of it before I by the SLP single if it gets worse maybe I will move the sensor to the neck of the can.
