Any tips on suspension bolt removel that are dependent on each other to get off
Race
I'm changing my old track out so I need to take the suspension out. How do you get the four suspension bolts (two in rear & two up front) off without spinning one side to the point you can't get it off. 03 Polaris Escape. Thanks any help would be appreciated.
normally if ya break one loose with an impact, then resnug it and go to the other one, they will come out.....
Leave the one side tight... cause you can't get it loose when the other one is already loose. On the other side, loosen and tighten it a half dozen times to get it freed up good. Then tighten it back down, back the other side all the way out then take the first one out.
sled_guy
Thanks Guys, I did as Ak suggested and it came right out. Thanks again Snowesters !!!!
If anyone has trouble with this, just take one of the bolts out and put in a longer bolt with a jamb nut on it, turn the bolt in a ways and tighten the jamb nut. Take the other side out and then remove the long one.
Good idea...never thought of that one.
