K
Klimbing Kitty
2010 M8 race gas. runs on one cylinder at idle. If i can get it on to boost both cyliinders kick in. Reeds are good. checked injectors by switching left and right and problem stayed on the left injector. Checked CCU by switching it out with another. Checked all grounds. Checked plugs and changed for new ones anyways to make sure. External fuel pump puts out tons of pressure. Coils are good. grounds are good.
will check wiring harness to the primary injectors to make sure it is ok tonight. After that the only thing i can think of is a crank seal?? I was told i can spray WD40 on it while it is running and if it sucks in the WD40 it is the seal.
Any other ideas guys
thanx
KK
thanx
KK
