Any one running a high compression piston?
I have a 2009 CRF 450 with a LT kit under it bike worked great last season, but it's time for a rebuild so I was thinking about running a 13.5:1 piston. Just curious if anyone has done this and what your thoughts were. Riding altitude is from 5000ft-10,000ft.
Ye
I just installed the high comp piston in my rmz last weekend. Run premium gas at altitude and should be good.
I put on my dobeck fuel controller cuz I had one to try out too.
07 crf 488 with a cp 13.5 -1 piston running premium at sea level no det. you probaly get away with a 14 -1 piston at altitude with a mix of race gas and pump fuel.highly rec the CP pistons
Con rod to crank bearing is a weak point , make that part of your rebuild
Agree on the rod and crank.Carrilo makes a great rod,send off to crank works for a rebuild and balance.Also ck Falicon rods i believe
