Any Difference in pipes
HammsRMK
I have a dyno port pipe, and a pcv5 on a sled i just bought are all pipes the same? I see most people run SLP with the pcv5. Just wondring what map should be in the pcv5, would it be the same as the slp or do they have different ones for different pipes. The sled also has the dyno port can too. Thanks any imput would be great.
No, all pipes are different. You will need a map specifically for that setup.
I'm really not trying to be a jerk, but if you weren't sure if all pipes are the same you probably shouldn't mess with anything other than a completely stock snowmobile. Otherwise it could be very expensive and very frustrating for you.
The sled I bought came with the dyno port pipe and can with a pc5 i was just wondering if they run better with slp or if all pipes had same maps. Im hope the guy that had it done before I got it had the right map. Also when i bought the sled he didnt give me any cables for the pc5.
