Looking for feedback and pics of anyone whose running turbos other than Mcx on their Nytro.
BD is suppose to have theirs out after the first of Jan from what I hear.
I have been running the Impulse kit since november, and it rips. The snow in Alaska has been skimpy, but I have still been able to put almost 400 miles on the Nytro (250 turbo miles).
I saw pics of Outlaw Motorsports BD setup. It is one killer looking sled! Would like to run the exhaust I put on so.....front mount research time.
Anyone seen Outlaw's orange Nytro up close?
I think if you want to use your current exhaust the rear mounts would be the best option. Most front mounts from what I've seen have tunnel dumps or very short exhaust setups. Going off of the apex chasis, this is also the case.
My silencer has the same ID on the inlet and the same length as the stock muffler. Will that work?
We ran the Alpine kit for 3 days. The first day we pushed the throttle bodies off and could not make boost. I should have glued them on when I installed (whoops). Pulled throttle bodies next morning in the trailer, cleaned the boots with brake clean and removed the buckets from the clamps. Put her all back together and first pull up the trail... 20 lbs boost. So turn controller down and get it up top, and now makes 15 lbs boost and rippin fast. There is no heating issues at all and throttle response is great. I have the 28rs turbo. I will try to post pics today when I unload the trailer.
NM
Darko might have an answer for you, since he has been changing around the MCX exhaust to be a tunnel dump.
