Ok, for my 13th birthday, my grandparents bought me a 69' chevy C-20 that had a 396/turbo 400 in it. Project truck, they had one just like it and wanted to pass one on to me. My question is how do I know the block is still good? The guy before me slid new crank bearings in without touching the crank, long story short, when I pulled the bottom end apart, it had eaten the thrust bearing and the crank flyweights had been rubbing on the side of the clock bearing webing, turning it shades of blue and purple. Does anyone know if its still good? Also, it's getting stroked. Can't live with the high rpm 396 with these gas prices, but I don't what to go with, I know people with a 4" stroke in these, but how about a 4.25" stroke? Probably going to go with a Scat cast crank as this motor will only be turning around 5500. I'm dropping the turbo 400 for a Borg Warner Super T-10, it has 3.26 gears in the Eaton 9". I got a ripping deal on a Comp Hyd. roller cam, 208/212 dur., .520" lift and 110 LSA. Also doing roller rockers, probably 1.7:1. The heads are lacking, as of right now they will be ported passenger car irons unless I can come across a 2 grand for alum.. Not sure about carb and intake yet, probably a Weind dual plane and a Speed Demon. It is a 2 bolt main block, but its getting ARP studs everywhere I can. Trucks a daily driver and because of this, an EFI system might also be in the cards. I know this is a lot of info to swallow, but If someone could give me some feedback on this setup and and the block, that would be great! Thanks for help!
