D
dmkhnr
Hi guys,
I just bought a 1000 summit x which has a bad lower rod bearing.
I split the case today and sent it off to JJmachine for a rebuild.
I want to get my ducks in order for the rebuild, and have a few questions:
#1 The water pump shaft cavity was filled with oil. Is this normal? Do I need to fill it at install?
#2 The crank bearings have a small pin in them. Does this rest on top of the case?
#3 Any trick to lining up the outboard balancing gears?
I'm sure I'll have more questions as I get started.
thanks
DK
thanks
DK
