antifreeze
so i am changing my antifreeze and cant getthe air out. I seen it on here a wile back but i cant find it. I just need to know how to do it. thanks.
Raise the front of the sled and run it until you have heat at the rear exchanger. Let it cool, add if you have to and do it again, usually by the third time you have most of it out Go for a short ride and let it cool off again and check it.
The book says you have to lift the front 1-2', run 3,000-3,500 RPM until the front cooler is hot. Lower the front, let cool down, refil. Raise the rear 1-2' run at 3,000-3500 Rpm intil front cooler is hot. Lower and cool. Add coolant and repeat until rear cooler gets hot. Real easy to airlock.
Keep the bottle full while running.
It's a pain, I am in the process with mine now, breaking in a new motor in the garage. 1 foot is not enough. I get a little more air out every time I heat cycle it.
