antifreeze bottle heat shield
Just got a 2010 crossfire 8, first ride the light was comming on, went back home let it cool and checked, it took about 8-10 oz antifreeze. I have not seen the light again. Also did anyone notice on the new (maybe on older ones too) crossfires and Ms that the shield for the antifreeze bottle coveres the cold level so you can't see the correct fill level. Also the pull rope, because of the shield, does not go through a rope guide and slides against the side of the sheild. I removed the shield and using a 4" grinder cut a slice into the side of the shield along the bevel line of the shield about 1 1/2" long so as to rotate clockwise onto a piece of plastic that is covered with foil to expose the rope guide. Rope now follows correct path............mark
