Good morning!
I am new to your forum, however I am not new to forums.
I have worked as a machinist/mechanic since the mid 60s.
Heavy equipment, HP Auto, motorcyles, Volvo Penta, etc.
After having read a few old threads on this topic, I decided to join Snowest.com.
I know that we are in the Skidoo forum..... I own and ride Skidoo........ but please bear with me because it applies to Skidoo as well!
Subject:
Tapered shafts/shivs and Anti-Sieze/Never-Sieze usage.
I pulled a Arctic Cat primary clutch yesterday and ended up using quite a bit of Mapp Gas heat in order to expand and allow the two to separate. I almost gave up and started making a plan to cut and relieve the clutch tapered area.
After one last attempt......... pop.... she came off!
Now.... this simple removal should not have been so difficult!
Crankshaft taper and female taper did show some signs of odd and uneven contact.
After lapping the crank to the replacement clutch taper, I cleaned up the lapping compound and did a dry fit.
All appears to be OK.
I then applied a very thin film of my favorite Never-Seize.
With very little force, the two (male and female tapers) gain friction very easily.
Now...... I have read both takes re; using and not using anti-seize/never-seize on the tapers.
I have been using the Automotive version of anti-seize/never-seize for over 45 years. I have never had an issue IF the two mating surfaces have been properly "lapped" with the correct lapping compound. This would be for both "keyed" and "Non-Keyed" tapered shafts!
Of the pros/cons that I've read here, the ones who have been successful with using a light coating of anti-seize, appear to be seasoned mechanics. In other words, I liked how these people explained it.
I would love to hear more Pros and Cons by those of you who have had experience with both good luck and bad results!
Perhaps not only why it Does NOT work, but also why it DOES work!
I am planning to reassemble using a light coating of anti-seize.
The clutch-to-crankshaft bolt will be torqued again after first warm-up.
Thank you in advance.
Rick
Subject:
Rick
