M
Mister907
sittin around waiting on parts, so ive been tinkerin with my 08 nytro. just moved the taillight out of the way. wasnt too hard, and if you have the grinder and or dremel tool, its relatively cheap. i didnt have to buy anything, had it all hangin around in the garage. used: small piece of card board, 4 rivits, two small wire hangers, two small bolts w nuts and washers. tools: black sharpie, razor knife, drill and 5/16 bit, grinder w metal cutting wheel, dremel w metal cutting wheels (x2). after removing the light set up, i traced a pattern to the card board.
transferred the pattern to the back of the machine
drilled and cut
the dremel made it easy to get the angled parts
drilled and cut
