What you see in the picture is the bottom mount for your exhaust.
See those flanges on the top of the bracket?
Well those flanges are rubbing into the aluminum oil line that rests above and touches the bracket right on both flanges.
My aluminum oil line was rubbed about a 1/3 of the way through. It looks like all of our sleds would have the same issue.
I plan on taking a dremel tool and grinding those flanges down at least half of the height if not more. Then I plan on wrapping that oil line with a section of radiator hose or something like that.
If that oil line wears through we are all set to see alot more youtube videos of these sleds on fire. It is not a matter of if this will wear through, but when.
This is a life safety issue folks, and you should alter that bracket or somehow bend the tubing so that it does not rub.........
At any rate,,,,,,,,,,,,,, have a look at yours.
![IMAG0196.jpg IMAG0196.jpg](https://www.snowest.com/forum/data/attachments/133/133385-d27f9a7af35571a686df7772040b8216.jpg?hash=0n-aevNVca)
