I did this project earlier this fall except I did a 174 3".
The skid set back is not equal to the drive set back.
Again, there is so much room between the track and the front of the tunnel it's awesome, even with the 3inch lug! I've got no problems with snow evacuation!!!!
Unfortunately, I've only had this bad boy out once. The performance gain over last years set up (159x2, stock chain case) is flat out amazing. The early snow didn't have much of a base basically a lot of fluff on hard ground/rocks/sticks, etc... This sled is just a tractor!!! Half throttle on hills that I would have had it pegged last year. The only thing I've changed is my gear ratio, clutching has stayed the same.
Nice job on install ezsmoke420! If you have any other questions or need pictures let me know...
Andy
CNC billet aluminum dual piston caliper*3.5" bolt mounting center fits many polaris and arctic cat chaincases*dual piston design for phenominal braking power*top load design for easy pad maintenence*anodized black*use with our bolt on adapter for older polaris top load chaincases(some wedge chassis,all gen2,evolved,aggressive chassis)*perfect match for the wilwood master cylinder.
