another diamond drive??
T
theUltamateTBM
So I broke the bolt off in the output shaft of my diamond drive and have tried everything to get it out I have a drive out of an 07 with mechanical reverse will that fit in my 06 m7 or am I better off ordering a bdx thanks
I don't see any reason why you shouldn't be able to center drill the bolt stub and use a easy out along with a little heat to soften the blue Loctite. If the shaft is already messed up I guess a new gear would be in order. A machine shop could fix it for you but if mess away a couple hrs. on it you would be better off just replacing it. I doubt shaft from the reverse box would work, guess I've never looked at them for interchange. There should be plenty of used parts around or just get the new gear set from BDX for $200.
I have heated it drilled it all the way through and tried from small to biggest easy out that will fit it won't budge out so if I order a set of gears from bdx does that include the gear that's part of the output shaft
