amp style brake lever for standard RMK?
Does the amp reduce the distance you have to reach to apply brake vs. Stock?
Does it fit the pro with no modification?
Sent from my XT1254 using Tapatalk
Read the post bro, the AMP one does not fit Hense why he is asking for a diff option
Don't have one, but got a hunch that Skinz lever is pro/Hayes Cyclone master cylinder only. I'd ask them if in doubt before trying to hunt one down for the RMK.
And they still have their online ordering blocked? Only real reason to do this is to drive orders through a distributor network. Otherwise, it's a non-business model...
The amp style is a direct replacement for the Pro brake lever. It's a shorter reach by 1/4" ish so if you have smaller hands it's pretty slick if your unhappy with the stock Pro brake lever. Pull the brake lever pin and swap and your back in business with the AMP style. It will also work for the standard RMK I found, however you will NOT have a parking break if you use it! That seems to be the difference between the PRO and the standard RMK, the PRO has the little bit of metal you flip over to set the parking break where as the standard RMK has the red lever that catches steps on the inside of the brake lever to hold it in place. Using the AMP style on the standard RMK means you have no parking break, but that can be handled with a strap, zip tie, etc. since I only use the parking break when trailering, etc. So after all the trial and error my wife hopped on the sled and didn't like the AMP style lever so back to stock it went lol.
Thanks for the info RexFlex. That is what is was hoping the case was as I'm looking to shorten the distance for the wife and didn't want to drop a ton of coin on the skinz lever.
