I'm going to ask another ingorant question. I just put on and RKT secondary, comes w/ the BD belt deflection adjuster. How far out from the end cap of the helix should adjuster be? To tighten the belt you have to loosen the adjuster, do you then have to run the sled a bit to get the sheaves to come together? Every time I stop and look at the clutch it seems the belt is riding a little different in the sheaves and I can't get it to consistantly ride high in the secondary. What am I doing wrong???
I'll tag on to this question since tonight was the first night I've tried my BDX adjuster and it sounds like we may be having similar issues.
Even with the adjuster all the way out (a gap) the sheeves don't seem to come close enough together to get the belt to ride quite 1/8" up or to be tight enough (deflection of 1 1/8" to 1 1/4").
Anyone have some tips here?
1 1/8" to 1 1/4" deflection measured from where? Middle of the belt pushing down w/ a certain pressure?
This brings me to something I just thought about..............When I last set my deflection by getting the track to turn a little, it seemed to hesitate on every revolution. I wonder if that would be an alignment issue. I need to look into that further. So what is the best way to check for alignment w/o having Cat's bar, which I heard aren't real accurate? Using a marker up the sheaves?
Aaron
