ALPINE LOW BOOST CHECK ENGINE
R
ridehard1212
Have a rear mount low boost alpine.. running av gas 6-8lbs boost.. sled runs great.. but a couple times a ride i will get a check engine light coming on.. How do i check what code check engine light is coming up with?
Anyone else get check engine lights coming on often?? as soon as i shut sled off and restart check engine light is gone..
Thanks Brandon
There should be a number in the screen at the bottom that is corresponding to the light showing. That number will tell you what you need to know as far as the light goes. It is common for a oil light to appear on first startup on some nytro's, mine did it at times if i just fired up and took off up a hill, after idling for a second it would go out, or after restart. Not a big issue.
No out of the ordinary codes on mine. I forgot to plug a sensor in and it lit up, oil, fuel low lights, etc. you riding that at low altitude? Why the 100LL with 6psi?
Warning
I think the yellow warning comes on when fuel low. And what light comes on and which symbol shows on the screen cause it should flash a number if its coding up? Also when i roll mine nd start it up again the yellow light comes on with nO code but a oil symbol appears on the screen. I woild chech yoyr oil level
mostly 7-8lbs.. 100ll to be safe as i do ride as low as about 2500-3000ft.. and at 8lbs i think thats starting to push it
