Ohhh, and also....antifreeze DOES burn LOL!
Just when it's installed and running, do severel close checks on all oil, coolant fittings after running it . I did my install myslef, followed the advice to a T and I only had to tighten my coolant return from the turbo just a smidge.Never had a leak of anything since,nor any problems. Also, make sure to use the correct length new header bolts, with "Nord-Lock" washers, even a small drop of Loctite blue on them. I had a couple bolts back out and was my fault for using the old factory bolts by mistake.
