Been having some back shift issues on my my alpha the last few rides out. I don’t remember it being like this earlier in the season, but snow conditions have changed. So I bought a new helix to try. When I pulled my secondary clutch apart I noticed the roller on one side was jammed and stuck between the two angles. The first 1/2 of roller travel was fine until the roller got up between the two angles, then it would jam and stick. So stuck I had a hard time getting the roller out. I’ve had a lot of team secondaries apart and the roller has always just lifted out easily. I had replaced the spring at about 160 miles and it came out easily. Now with 450 miles it’s quite stuck. Can’t find any damage to the helix at all. My guess is that’s what has been screwing with my back shift.
First pic. This is where the roller starts to stick, and gets way worse as it shifts out. Roller should glide smoothly up and down the ramp.
Second pic. Roller shouldn’t touch this side. Mine has pretty good wear marks.
Third pic. Helix with a lot of miles on it. Zero wear markets, roller doesn’t touch
I’m guessing that if there is one bad helix there are probably more. So if your up or back shift starts getting worse, something worth checking.
