We've developed a line of enclosed trailer cabinets and storage bins that we'd like to show ya!
The A.C.E. (adaptive containment engineering) trailer systems line is unique because it allows much more efficient use of the small spaces available in our trailers. The main cabinets are the only items that require drilling holes in your trailer walls to mount-the accessory cubbys, shelves and racks all attatch to the main cabinet through the use of our patent pending "tab lock" easy mounting system.
For example: here is one of our 34" helmet/gear cabinets.
notice the laser cut pattern in the sides, the pattern is also on each shelf bottom and on the back wall. If you purchase any of our accessory ad ons, simply choose what location and orientation on the cabinet you would like it to mount to and use your thumbs to push the 2 closest tabs out...
now, all you have to do is slip the square holes in the accessory shelf over the tabs on the cabinet...
To secure the shelf to the cabinet, use the laser cut hole in the tab as a guide and drill 3/16" holes through the accessory in both locations...
Install the pan head screws and nylock nuts supplied to permanently secure the accessory to the cabinet-thats it!...
we have several accessory shelves/bins/racks/cubbies to allow you to arrange your storage to best fit your space and specific storage needs. Many of them can be mounted in more than one orientation i.e. vertical/horizontal/front/back or bottom...
Here are the details on what we have in stock so far....
First and foremost...the A.C.E. 34" cabinet...
also available in stealthy black powdercoat...
The cabinet sells for $229.99 and add 28.00 for powdercoating
next, the A.C.E. 34" gear cabinet with heavy duty utility hangers...
the gear cabinet with hangers sells for $139.99 and add 19.00 for powdercoat
this is the A.C.E. 34" oil and aerosols cabinet-it has our tab lock system on the bottom to allow installation of our smaller "under bins" to the bottom for more storage room without more holes in your trailer! this sucker holds quarts, gallons or pints-including the square gallon jugs along with aerosols of all shapes and sizes-a very handy cabinet in a trailer.
here it is with accessory "under bins" installed...
the aerosols cabinet sells for $99.99 and add 19.00 for powdercoating
Now we have the accessory add on bins and components...this is the A.C.E. 12" essential tool rack. It features a laser cut pattern specific to those common tools we all use and need to keep out where they are handy to grab. crescents, pliars, screw drivers, vise grips, flashlights etc...
this useful little guy sells for $35.99 and add 12.00 for powdercoating.
this is the A.C.E. 12" under cabinet cubby. Just like it says, this one is designed to mount to the bottom of either the 34" cabinet or the 34" oil and aerosols cabinet...
the under cabinet cubby sells for $28.99 each and add 12.00 for powdercoating.
this is the A.C.E. 12" side hanging cubby with shelf-notice many of these items also feature laser cut holes in the sides for handy places to hang straps/bunges and other odd stuff!
and this is the A.C.E. side hanging 12" cubby with light duty hangers (cords, ropes etc)...
the side hanging cubby with hooks sells for $35.99 each and add 12.00 for powdercoating.
This is the A.C.E. tie down rack/paper towel holder. these are supplied with two tubes as shown. use just one tube to hang your paper towels or blue paper rags or use both tubes and you can store a whole pile of tie down straps! This is one of the items that can mount vertical/horizontal on the sides or bottoms of the cabinets...
the 12" tie down/paper towel rack sells for $24.99 each and add 12.00 for powdercoating.
here's one we think is pretty cool-this is the A.C.E. high or low mount tire rack with integral bottle jack storage. These are manufactured from high grade steel, laser cut , bent and powdercoated. This tire mount holds full size tires only(15" or bigger) and comes with "knock off" style nuts so you can mount and dismount the tire without tools! the shelf on the back secures your bottle jack behind the tire, out of sight until you need it. you will need to supply a small bunge to secure your specific jack since sizes vary. The mount extends to the edge of the tire to keep the tire off of your wall and eliminate damage.
The tire mount sells for $ 109.99 each and powdercoating is standard.
here is a slick mount for holding those cumbersome 4 way lug wrenches-bolt it to the wall anywhere you like, drop the wrench in and secure it with the rubber strap to keep the rattles away!
the lug wrench bracket sells for $24.99 each and add 12.00 for powdercoating.
This product is the first of a whole line of quick release components we are manufacturing that can be quickly and easily installed, moved or removed from your trailer! These components mount into e-trac tie down strip with a quick release mechanism. If you don't need it in the trailer this weekend-just un clip it and throw it in the garage!
This is the A.C.E. trailer systems quick release motorcycle tire chock...
here it is in use...
as you can see, the bikes sit at a 45 degree angle in your trailer..why? 'cause you can cram a bunch more of 'em in that way! more efficient use of space people!
you can just line them up on down the trailer...
and when you aren't hauling bikes...just unclip them and quit tripping over them!
These sell for $129.99 each add 14.00 for powdercoating the aluminum-
This is the Fastrax A.C.E. trailer systems quick release table-
At 28 x 30" this is a camp table that you can actually sit the family or buds around and not feel like you are sitting at a 3rd graders desk!
Our table can fold up or down against the wall for storage while on the road and quickly unclips from the wall so you can get it out of your way when you don't need it!
The table leg stores under the table top when folded and features a finishing plug to protect your floor.
Our tables take up less than 3" when folded up against your wall so they don't interfere with your loading and unloading.
The A.C.E. table sells for $190.99 add 28.00 for powdercoating
This product requires e-trac or our mounting kit to install in your trailer.
Our mounting kit sells for $29.99.
Fold up beds and benches are almost ready too!
here are a couple shots of a trailer we recently outfitted to give you an idea of some possible uses and combos...
We are launching a new website in another couple weeks so bear with us for now as we keep posting up new products here!
Curt
![2011trailercabinetandproducts026.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts026.jpg)
![2011trailercabinetandproducts034.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts034.jpg)
![2011trailercabinetandproducts035.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts035.jpg)
![2011trailercabinetandproducts038.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts038.jpg)
![2011trailercabinetandproducts039.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts039.jpg)
![2011trailercabinetandproducts050.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts050.jpg)
![2011trailercabinetandproducts029.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts029.jpg)
![2011trailercabinetandproducts081.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts081.jpg)
![2011trailercabinetandproducts001.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts001.jpg)
![2011trailercabinetandproducts089.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts089.jpg)
![2011trailercabinetandproducts011.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts011.jpg)
![2011trailercabinetandproducts091.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts091.jpg)
![traielrproductinstalled010.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled010.jpg)
![2011trailercabinetandproducts016.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts016.jpg)
![2011trailercabinetandproducts097.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts097.jpg)
![2011trailercabinetandproducts021.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts021.jpg)
![2011trailercabinetandproducts094.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts094.jpg)
![2011trailercabinetandproducts107.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts107.jpg)
![2011trailercabinetandproducts012.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts012.jpg)
![2011trailercabinetandproducts102.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts102.jpg)
![2011trailercabinetandproducts031.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts031.jpg)
![2011trailercabinetandproducts105.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts105.jpg)
![2011trailercabinetandproducts086.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts086.jpg)
![traielrproductinstalled009.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled009.jpg)
![2011trailercabinetandproducts104.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts104.jpg)
![traielrproductinstalled007.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled007.jpg)
![2011trailercabinetandproducts058.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/2011trailercabinetandproducts058.jpg)
![traielrproductinstalled034.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled034.jpg)
![traielrproductinstalled016.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled016.jpg)
![traielrproductinstalled017.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled017.jpg)
![acefoldingcamptable002.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/acefoldingcamptable002.jpg)
![acefoldingcamptable004.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/acefoldingcamptable004.jpg)
![acefoldingcamptable005.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/acefoldingcamptable005.jpg)
![traielrproductinstalled001.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled001.jpg)
![traielrproductinstalled027.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled027.jpg)
![traielrproductinstalled011.jpg](http://i801.photobucket.com/albums/yy299/fastrax_photos/Fastrax%20ACE%20trailer%20storage%20solutions/traielrproductinstalled011.jpg)
Curt
