I ran across AK Technologies RFM oil filter. Curious if anyone knows anything about them. I believe Andrew is from Langdon. Looks like a cool idea. Not sure what bikes it will be made for yet. Snowbike could use some better filtration imo. This is what i copied from Facebook
“The new project has finally come together. First of it's kind, Radial Field Magnetic Filtration. Using industry leading patented technology from One Eye Industries, I have created the next level in engine oil filtration for today's high performance machines. Over the past few months I have been testing this new design in my 2016 ktm 500 exc and the results have been phenomenal. I have over 40 engine hours of testing with 120 hours currently on the bike.
These rods have a magnetic field that travels around the surface of the rod instead of each end like a typical magnet. When oil is pumped through an engine by means of a gear pump, the particles within the oil pick up a static charge. Radial Field Magnetic Filtration is so strong it can pick up on non ferrous particles containing this charge. Also this filter can pick up particles smaller than 1 micron which a stainless or paper filter cannot pick up. (see results pictures). These filters will be great for sports like snowbiking with an increased load on the engine and clutch! Don't let that clutch dust slip by your paper filter!
Quick and easy to clean! simply remove it from your bike, wipe off with a rag and re-install! Never buy a paper filter again!
Extend your oil life by using superior and easy to clean filtration!
Pricing will be available in the new year!”
