Airfilter
kinneyt
What is everyone running for Air filters without the TSS?
How do you like your set up?
What would you change or improve?
Where did you get you filter / prefilter from?
I've got a 2015 YZ450F, with the forward intake, so different set-up for sure but maybe different problems too..
I made a cold air intake with large rad hose and exhaust adapters from the automotive store.. This is based on a $200 model from CR Racing..I ran the hose (with a bend) up from the throttle body and out the top of the filter cover..I had to remove the air filter, cage and throttle body adapter (boot) and drilled a hole in the cover..I used a foam pod (like for ATV or Turbos..) without the foam and covered it with a waterproof cover (snow proof)...Problems aren't there yet but I'm questioning the air temp sensor position (stock) with the plumbing bypassing it..
34
