C
Clarke673
Somewhere between too dumb to quit and flat earth
Ok so I must choose to make my own custom air box or just use two k&n air filters. They would be mounted to my carbs.
Some reasons I have heard for using an air box over just a filter is that you will have an excess air supply. You use the excess amount of air for when you are cruising along and you just punch the throttle. So the air inside the box is used to get the engine going and then it starts to pull more air through the filters obviously being slightly restricted compared to just pulling in air with no resistance.
Another benefit to having an air box is that the filters will be drawing air farther away from the engine meaning less steam and heat being pulled in.
Im not sure what I should do so any opinions on the matter would greatly be appreciated!
