The Fox floats are completely adjustable with your own air pump. Ryde fx can be adjusted by a dealer or someone who sevices shocks
What is the difference between Ryde FX 2.0 Air shocks and Fox Float Air shocks?
FYI, You can put nitrogen into all air shocks to minimize pressure changes due to temperature, you just can't use the pump to adjust them on the hill.
ummm, how much nitrogen is in the air around us?![]()
Only 78% by volume. I think the 22% of the other stuff is the issue (mostly oxygen) is the issue as it changes volume, and therefore pressure, as the temp changes, more than nitrogen.
in the end, for the conditions the shocks on a snowmobile are used in, it doesn't make a difference. There isn't a person on this forum that could tell the performance difference between a nitrogen filled strut and one filled with a bicycle pump.
