Air intakes for M series
V
Vorman
New member
Has anyone taken flo-rites and placed them in the front of their M-series below the bumper and have them direct air into the front of the airbox (putting a foam sealed hole in the front of the airbox as well)? Was thinking that when you are pushing powder it would be plugged off but when you were on the gas or climbing, the snow wouldn't stick and you would have another air source. Also was thinking about flo-rites in the hood along the line of the normal intake tract with the same foam sealing off the powder. Just looking for other sources of air as it doesn't take much to plug off the stock intakes.
i have taken 4 bulleyes and put them into the top or the airbox under hood right up close to the hood vents. then i took slp matterial and glued it over the front hood vents to keep the snow out. shouldn't be pulling in much hot air down there and i don't get bog in deep deep powder now
But I have twin pipes
that almost sit on the air box and cook everything around them. Was hoping to avoid the air coming from the inside as I know I plug those front vents on occasion.
i put them in the nose cone and drilled the same size holes in my air box closed up the top intake and it worked good in the spring didn't try it in the deep stuff dont think it would have worked going to get timbersled this year.
