T
towngrunt
I had read on here many people had air bubbles in their oil injection system, mainly right out of the oil reservoir. After reading this I looked at mine and noticed the same bubble. I removed the bolt and the rubber band that holds the tank on and raised the tank above the bubble and used a heat gun to heat up the line and oil and waited til the bubble disappeared. Continued to warm it up for another 5 or so minutes and reinstalled the tank. I went for a ride the next day and noticed that I used as much oil in the next ride as I used in the previous 2 combined. This could be part of the problem with a couple of these motors going down.
I think most sleds have these bubbles in them and is restricting the oil flow. I am just thankful for at least running pre-mix in the first tank of gas. Everybody should check for this and eliminate the bubble. I checked it again once I had returned and the bubble had not re-appeared. The key is getting the line and tank warm enough to allow the oil to flow more freely.
